Ir para o conteúdo principal
Phone vibrant doesn't work
Phone vibrant doesn't work how can i fixt step by step solutions
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If you have investigated software solutions such as restarting your phone or even doing a factory reset and are sure you need to replace the vibration motor, here is a guide giving you the instructions you're looking for.
Galaxy A30 Vibrator Repair - Free Guide - SOSav.fr
The guide is written in French, but if you use it with a browser that does translation such as Google Chrome, it is quite usable and well written.
Esta resposta foi útil?
Pontuação 1
@mesfintedila before replacing the vibrator perform a hardware test and see if it still works with that. Dial *#0*# to get to the Samsung hardware diagnostic test menu. There will be an option to test the Vibration. Check that. If it works then the issue your phone is experiencing is most likely related to a 3rd party App that interferes with the normal vibration operation. Uninstall those Apps and re-evaluate.
If it does not work in the hardware test menu, replace the vibrator motor as previously suggested.
Pontuação 0
Adicionar a sua resposta
Mesfin Tedila será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 238
