Ir para o conteúdo principal
Turn 17 "screen into external monitor?
My computer died a horrific death (cider was involved), and I've salvaged the hard drive, and the other removable stuff, but what I really want to do is pull the screen out and turn it into a VGA or DVI external monitor. It could then be a very low power, small footprint wall-mountable device.
Any ideas as to how to build a VGA or DVI adaptor for it?
This is NOT a software question. It's a hardware/wiring question.
Esta pergunta é pertinente?
Pontuação 2
3 comentários
When you change the question the answer does not fit. Please just add a comment to help clarify what you want.
por
Any success with this attempt. Even I am looking for the same solution. Kindly share in case if you have one.
por
Looking for the same solution....
por
Adicionar um comentário
2 respostas
Solução escolhida
Here's how to do it: http://www.macupdate.com/info.php/id/229...
Esta resposta foi útil?
Pontuação 2
3 comentários:
No, that's software. I want to physically wire the display to a vga port.
por
Ooh, close, but the apple laptop screen has a weird "apple created" plug that goes into the motherboard for video. That plug needs to be converted into a VGA or DVI plug.
por
Try this...
Reuse the flat LCD panel to a vga monitor
Pontuação 1
Adicionar a sua resposta
deadtroll será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 13,618
