Ir para o conteúdo principal
O ZOYI ZT-703S integra as funcionalidades de um osciloscópio, um gerador de sinais e um multímetro, proporcionando uma ferramenta multifacetada para diversas aplicações.
Multimeter function is not working
Hello. I have a ZT-703S with a problem: the oscilloscope function works fine, all buttons work, and it takes measurements normally. However, when I switch to the multimeter function, only a few windows appear, including the analog scale, but no numbers appear. It no longer responds to functions like diode, resistance, and voltage. I updated the firmware and reset the settings to factory settings, but it still hasn't returned to normal. Does anyone know how to fix this?
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
Hi @brunogouve48763
had you checked the internal fuse?
por Compartilhar
Yes, I checked the fuses, they are ok. I haven't found the solution yet.
por Compartilhar
Isn't the issue in below Youtube video a similar issue as what you have?
https://www.youtube.com/watch?v=P6QntvNA...
He was a able to fix it by re-soldering the chip.
por Compartilhar
Hello!
Yes, the same problem as in the video.
However, I resoldered the component as instructed in the video, and it didn't work. When measuring with an oscilloscope, there are frequencies in the transformer's primary and secondary. But it still doesn't work.
por Compartilhar
Adicionar um comentário
1 resposta
Ah OK, sorry to hear it didn't work for you.
Sorry that I can't be of more help.
Hopefully there are others who can.
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bruno Gouvea de Paula será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 58
Ao todo: 521
