Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a terceira geração do controle DualSense do Sony PlayStation 5. Identificado pelo número de modelo CFI-ZCT1W e placa-mãe modelo BDM-030.
Audio jack not working
The audio jack was working fine until yesterday but today when fired up my console my wired JBL headphones wont connect. I tried with other controller and they seemed to work fine so not a headphone issue definitely a controller one... anyone know how to fix this?
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Hi Sam!
Is the Dualsense it's firmware up to date? Just in case!
Do you use the controller on the PS5 or PC?
Do other headsets work or airpods or whatever?
Thanks!
por Compartilhar
I use it with ps5 and yeah firmware is up to date👍
por Compartilhar
Okay! That’s good! Do you have any other headset to test?? This would be the ultimate test.
In the worst case, you do need to replace the headphone jack.. this requires soldering and soldering experience!
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hey,
This is a common issue with PS5 controllers, I've attached a YouTube link for a couple quick diagnosis methods. Unfortunately if none of these methods get your controllers audio jack working again you may have to replace the audio jack which will require you to disassemble the controller and do some soldering.
Here is the YouTube link.
https://youtu.be/0goVWJZ_Ozo?si=A6N_OHSO...
Hopefully this helps, best of luck!
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks so much man cleaned it with alcohol issue resolved 👍👍
por Compartilhar
All good, glad you got it sorted.
por Compartilhar
Glad that it is working! Have fun gaming again!
por Compartilhar
Adicionar a sua resposta
Sam Medadkar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 79
Últimos 30 dias: 347
Ao todo: 4,649
