Ir para o conteúdo principal
O HP Probook 4530s faz parte de uma linha de notebooks empresariais fabricados pela Hewlett-Packard (HP). Ele é da Série S (série padrão), composta por telas equipadas com processadores Intel.
I cannot hearing any thing
my speaker and volume is corect but when i open to see any video sound not comes
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello!
I understand you cannot hear sound when you play a video.
Let’s try some simple steps to fix it:
  1. Check sound settings:
  2. Click the speaker icon near the clock (bottom-right corner).
  3. Make sure volume is not muted.
  4. Click on "Open Sound Settings". Make sure the correct speaker is selected.
    1. Try playing other sounds:
  5. Can you hear system sounds (like when you get a message)?
  6. Try a YouTube video and also try a video saved on your computer.
    1. Update sound driver:
  7. Press Windows Key + X and click Device Manager.
  8. Find “Sound, video and game controllers”.
  9. Right-click on your sound device (like Realtek), and choose Update driver.
  10. Or choose Uninstall, then restart your computer.
    1. If using a browser (like Chrome):
  11. Try another browser.
  12. Check if the tab is muted (right-click the tab).
  13. Clear browser cache.
If sound still does not work:
This laptop (HP ProBook 4530s) has the sound card built into the motherboard. You cannot replace it easily. But you can use a USB sound card as a solution. These are cheap and work well.
Good luck! Let me know if you need more help.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Oscar Perineum app maker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 205
