Ir para o conteúdo principal
Informações de reparo para a linha de notebooks HP 600.
My laptop won't charge
I have two HP laptops. One of them won't charge using the same charger. If I charge the battery on the first one and place it in the second laptop work fine. I disassembled it and checked for the DC power jack, and it worked perfectly. Any ideas about what could be the problem?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Have you tested that the battery of the non-charging laptop works? If not, try putting that battery in the laptop that won't charge and see if you get the same issue.
por
@havynkrentz battery works perfectly. I guess there's some problem in the motherboard. Everything works as it should, except it won't charge.
por
@anwar29099
What is the full model number of the laptop that doesn't charge?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @anwar29099
Here are the motherboard schematics that should help.
Go to p.8 and following the DCIN path from pin 1 of the DC-IN cable connector on the motherboard to see how far you get. Also check that the circuits connected to the other pins i.e. 3,4 &5 are also OK
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Anwar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 150
