PC Not switching on
Both indicator and charging light do not turn on what could be the problem.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Have you verified the power supply is working? You should see 19.5 volts coming out from the plug. If you don't have a voltmeter, you may need to try the supply with a different device or try a different charger.
por Compartilhar
Adicionar um comentário
