Ir para o conteúdo principal
Informações de reparo e desmontagem para o e-reader Clara BW (preto-e-branco) da Rakuten Kobo, lançado em abril de 2024. Identificado pelos números de modelo N365, N365B ou P365.
Backlight not always working
My Kobo is a Clara HD, and for several months now I'm experiencing some issues with the backlight. I'm not sure if it's something hardware that can be fixed or if it's software.
Whenever I recharge my kobo, the backlight will stop working for a period of time that can range from a few hours to several days.
I've done quite a few tests to try to troubleshoot the problem with no success.
The level of battery does not seem to be directly connected as I encounter the problem no matter if I recharge when the battery is low or high and how long I recharge for.
Factory reset will always instantly fix the problem.
I would really appreciate any insight.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If Factory reset always fixes it, that seems like a software issue to me. I was going on a tear about battery charging and thermal expansion. But then I saw that a factory reset fixes it, so that seems more software related, even if it comes back.
Have you made sure you have done all software updates?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yes, the software and firmware are up-to-date. The only thing I didn't try yet is a downgrade, I might consider that and see if temporarily fixes it.
I'm afraid it's a mix of hw and sw issue.
por Compartilhar
Adicionar a sua resposta
Federica será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 50
Ao todo: 560
