Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
No Backlight
i need help on how to get back the light on my iphone it is very dark and i know it is the backlight problem but i need help to know how to fix it im scared to open it apart and miss the whole thing up!!!! please help!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi Layla. It seems you might need to replace the Display Assembly. Feel free to use our guide and let us know if you need any help. Best of luck!
Imagem de Replace a scratched or cracked front glass panel or a malfunctioning display for your iPhone.
Produto
iPhone 3G Display Assembly
$59.99
Esta resposta foi útil?
Pontuação 2
1 comentário:
Although replacing the entire display assembly is undoubtedly the easiest solution, particularly for the less tech inclined, it may not actually fix the issue. Replacing the components responsible for this function is likely to be what's required. But, it does entail desoldering and soldering of 1 or both components on the mother board. See this source, it provides a great zoom pix of component location http://www.amazon.com/CyberDoc-LLC-iPhon.... You can buy both components very reasonably or separately from a NYC vendor.
por
Adicionar a sua resposta
layla ahmed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 986
