Ir para o conteúdo principal
The fifth generation van had debuted at the 2007 North American International Auto Show with exterior styling by Ralph Gilles.
How to fix windshield washer fluid piece to come out
One of the sides on the van don’t shoot windshield washer fluid
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@jason81579 sounds like a clogged spray nozzle. Open your hood and check the hoses going to the nozzles and make sure those are connected and are not cracked/leaking. You can also try and clean the nozzle opening with a thin sewing needle. If none of that works, you will need to replace it. Check something like this video which will be similar to yours.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jason será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 34
