Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Pixel 8 Pro da Google, lançado em outubro de 2023. Identificado pelos números de modelo G1MNW (NA/AU), GC3VE (UE, Índia) e GE9DP (JP).
How to replace the rear camera glass
Hi everyone my pixel 8 pro rear camera glass cracked i was looking to replace it without replacing the entire enclosure do you know where i could get a kit and if it's difficult to do? Thanks
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
mine, too. I finally traded it in for a new one.
por
Adicionar um comentário
1 resposta
This is not an easy task for someone that does not possess the skills to do so. Unless you're extremely confident in your abilities to do this task I highly suggest you do not attempt it as you can do more damage than good. Have a look here and read the comments to judge for yourself.
It's certainly not an easy task so unless you have the skills and confidence to attempt this type of repair I wouldn't suggest it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Eli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 53
Ao todo: 346
