Ir para o conteúdo principal
Modelo A1990 / EMC 3359. Lançado em maio de 2019 com novas opções de processador de 6 e 8 núcleos.
Why is my trackpad stiff?
I got this MacBook today second hand and the battery is fine, so I'm pretty sure it isn't an issue with bloating. The click registers and works, but even on the firm setting, it feels quite light and not how a proper click should feel. I compared it with another 2019 MacBook Pro, and that one was fine. Is the issue with the trackpad itself? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The trackpad control logic is on the backside of the trackpad unit. I had to replace one due to tracking issues. The click action is a bit different as the same sensor surface reacts a bit differently as you compress it. I'm sure your trackpad suffered some damage likely a liquid spill that got onto the back side.
Here's the the needed park MacBook Pro 15" Retina (Late 2016-2019) Trackpad and here's the guide Substituição do Trackpad do MacBook Pro 15" com Touch Bar 2019. This is one of the easiest to replace as you don't need to remove the battery.
Imagem de Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.
Produto
$54.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ryzobyte será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 172
