Ir para o conteúdo principal
Repair guides and support for motherboards and CPUs.
Upgrade a Toshiba Satellite C650D With a C855D Motherboard
I have a Toshiba Satellite C855D Motherboard and a person's needs his replace but his model is Toshiba Satellite C650D are these interchangeable with each other?
Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@tj8799 this will only work if the physical layout of the motherboards are the same. Connectors and mounting points will have to be identical. Then you will need to check that the individual connectors are "wired" the same to ensure compatibility. I do not have the board views for these motherboards but I do have the schematics. Use those to check compatibility for the architecture of your boards. Toshiba Satellite C650DToshiba Satellite C850D C855D
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you will look at a c650D and image it next to a c855D and see if they look the same
Thank you again
por
Adicionar a sua resposta
tj8799 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 36
