Ir para o conteúdo principal
Panasonic released the CF-29 on January 1, 2004. It was designed to survive the harshest environments US Armed Forces, service personnel, and enthusiasts could throw at it. The Black Hawk CF-29 was released in 2009.
17 Perguntas Visualizar todos
PC will not boot, getting following error?
PC will not boot, getting the following error scrolling over and over again:
for Realtek: RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13
PXE-E61: Media Test Failure, check cable
PXE-M0F: Exiting PXE Rom
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
If the Toughbook does not recognize your Optical Drive (CDROM) or if there is no Hard Disk Drive then you will get this error message.
You may set the boot order in the BIOS by pressing the "F2" Function key and setting CDROM as the first boot device.
If you only have a 3.5" floppy disk drive then try to boot from diskette.
My name is Richard from canadanotebook. :)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
John Howlett será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 4,080
