Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Pixel 7 da Google, lançado em outubro de 2022. Identificado pelos números de modelo GVU6C e GQML3.
Screen detached from plastic safety frame
The battery was swollen and pushed the screen out, and when opening the phone I didn’t realise that instead of separating the screen with its frame from the chassis I was actually separating the screen from the safety frame.
The photo above should make it clearer.
Now I imagine the obvious answer would be to get a replacement screen but tbh having already spent 80€ for the battery kit I don’t think it’s worth it (also the screen is fine)
Any chance I can reassemble the screen and frame? What glue could work?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I ended up carefully cleaning frame and screen with isopropyl alcohol, then used a thin layer of T8000, let it dry a few hours before proceeding with reassembling the screen to the device, and finally leaving the phone under a stack of books for 24 hours.
I guess I'll have to report back in some time to see if it holds, but for now the result was quite good. It's most likely not waterproof anymore but I mean, at least it won't blow up anymore.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Giorgio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 154
