Ir para o conteúdo principal
Em 13 de dezembro de 2012, o Chevrolet Silverado de 2014 redesenhado, juntamente com o GMC Sierra de 2014 relacionado, foram apresentados em Detroit, Michigan, no North American International Auto Show.
Power Lock Partially Functional (Driver Rear)
Whether I select the lock/unlock button from my key fob OR the button on the vehicle door, my rear door on the driver side only responds 50% of the time. While this is not a major issue, it's been happening for about a year, and it's starting to drive me crazy. I try to avoid going to the dealership whenever possible.
I'm assuming this is probably an electrical issue or shortage, but I'm not exactly sure of where to begin.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Ben,
I ran into a similar issue with my son's 2003 Cadillac Deville. As it turns out, the problem was in the set of wires that run between the door frame and the door itself, so that's the place I'd suggest you start. Those wires get flexed every time the door is opened and closed, and as you can see from the harness on my son's car, eventually they give up.
Imagem
Yours aren't likely to be this bad, but you see what can eventually happen.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 213
