Ir para o conteúdo principal
Esta é a quinta geração do Honda CR-V.
How to replace Sun Visor
How to replace sun visor driver side
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
To give credit where credit is due, I found this on an eBay listing here.
Honda Accord Driver Left Side Sun Visor Replacement - Compatible & Durable - eBay
I know it says its for an Accord, but I was searching using the part number for a 2020 CR-V (since you didn't tell us what year yours is).
Anyway, it appears there's a little locking tab you have to press, then the mounting piece rotates and pops out. If you have a lighted mirror, there' also be a connector you'll have to unplug, but that appears to be all there is to it. Here's a picture from the listing showing you everything you need to know about removing and replacing it.
Imagem
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mark loman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 27
Últimos 30 dias: 126
Ao todo: 1,950
