Ir para o conteúdo principal
O Power Mac G5 é um computador desktop produzido pela primeira vez em 2003 pela Apple Corporation. Este guia analisará o processo de reparo de um Apple Power Mac G5, número do modelo A1047 EMC 2061 de 2004. Foi descontinuado em 2006 como parte da transição para a Intel, primeiro para desenvolvedores e depois para o público consumidor.
Help Identifying a Part from a G5 PowerMac
I'm currently reassembling a 2005 G5 2.0 GHz DP, M9747LL/A.
I have the following part but I can't remember where it came from, and I've not documented it in my photos I took during disassembly.
Can anyone help identify it?
Thanks.
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What did you do? That might offer a hint where to look.
por
I did a complete teardown as it was the most filthiest computer I've ever come across.
It was likely removed after the motherboard came out. Maybe somewhere around the HDD holders.
por
Adicionar um comentário
1 resposta
Solução escolhida
It's been quite awhile since I've worked on these older systems I keep thinking it's a logic board stand off holding the board off of the side panel (bottom side of logic board). Just behind the PCI slots you should see some holes where the pins and latch tab pass through to secure it.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I've added two more photos, do you mean in that area?
I realise it's a bit vague, and it is my own fault for not paying enough attention when taking it apart. But I do appreciate everyone's input on this.
por
Found it, it covers a cable on the lower left of the board near the RAM slots.
por
Adicionar a sua resposta
David será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 206
