Ir para o conteúdo principal
The Makita 9564PCQ is a discontinued cordless power tool designed for various applications.
Why is the roter winding sparking with brushes on the lamellas
I cleaned the space between the lamella and it sparks nonstop when energized.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @nafyadgetachew
What did you clean the commutator with?
If black emery paper or a sandpaper is used it leaves fine particles which can cause sparking to occur.
Try cleaning the gaps between the segments using a soft toothbrush and a vacuum cleaner and then clean the segments using a soft lint free cloth slightly moistened with Isopropyl Alcohol 99%+ (available from electronics parts stores).
Then try cleaning it again using either white or red emery paper
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Nafyad Getachew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 33
