Ir para o conteúdo principal
O Explorer de 5 portas e o seu companheiro Mercury Mountaineer foram inteiramente redesenhados para o ano-modelo 2002, ganhando uma aparência semelhante à do seu irmão mais velho, o Ford Expedition.
Turn signal stops blinking.
When I turn on my turn signal, sometimes it doesn't blink at all. Other times it blinks a few times and stops. The control lever was broken when I got the vehicle and I thought that was the cause but replacing the lever did not fix the blink issue.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Here are the next troubleshooting steps I recommend
  • Replacing the flasher relay is cheap, easy, and likely the solution to your problem VIDEO GUIDE
  • Checking the signal lamp Frame grounding point
    • There should be a wire that attaches straight to the frame from the headlight assembly. Remove it and sand underneath to remove any rust or corrosion, and replace it.
    • Here are the signal lamps' electrical schematics
Imagem
Imagem
These are the easy things to check. If this doesn't get you there, I'd recommend consulting a professional auto mechanic.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dan S. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 152
