Ir para o conteúdo principal
Guia de reparo e desmontagem do ASUS G15 G512LI de 2020, um notebook produzido pela Asus para jogos com orçamento limitado/leves.
Touchpad replacement and keyboard issue.
My touchpad is not working properly its like the mouse button is always clicked when i turn on the touchpad.so i want to replace it so how much does it cost?
And some keyboard button have problem like my number 2 button doesn't work but it works when i press it with any button pressed along with it - if i keep caps-lock and press 2 it does give 2 like that if i press shift and press 2 it gives the '@' symbol. So the key doesn't work if it is pressed alone but works when multiple key is pressed.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
$30-35 for the part to replace the touchpad, and the keyboard is probably tilted, making it be like that.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Karthik Uthaman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 205
