Ir para o conteúdo principal
Xbox Series X Regulator
Hello,
can someone tell me what kind of regulator this is please.
Update (07/27/25)
Hi,
if someone is faced with the same question: 74lvc1g08 nexperia (U51)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @pcbfix
If you don't get a better answer, found this link online which has the schematics. The download link was from here
If it also has the boardview file, using both the schematics and the boardview should tell you what type of component it is.
I can't verify this as I didn't download it to check (didn't want to sign up)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
pcb-fix será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 274
