Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Odd trackpad button clicking noise
This morning, my 2 year old MacBook's trackpad button started making these clicking noises every time I pressed on it. But it also depends on where I press down. The noise would be there on the right side sometime, and sometimes on the left. What could be wrong? Thanks
Esta é uma boa pergunta?
Pontuação 4
2 comentários
What exactly do these clicking noises sound like? How do they differ from that of a normal click? Is the actual upper case surrounding it broken in any way?
por
Normally, the sound it would make would this dull, quiet, *thuck*. Now it's this metallic, loud, *CLICK*. Sounds like a spring inside is in the way or something
por
Adicionar um comentário
4 respostas
Solução escolhida
Something very small could be stuck under your click pad. Try to insert the corner of a paper sheet under the click pad and slide it to remove the "intruder" out. Or buy the newer MacBook Pro, there's no click pad anymore in the trackpad assy LOL...
Esta resposta foi útil?
Pontuação 7
3 comentários:
Placed a piece of paper, moved it gently and found some slight resistance. Move the paper in and out and out popped a piece of dirt or food particle? Either way, after years of an annoying high click sound its back to normal!
Thanks!
por
This helped quiet the noise in the left click a lot -- thanks! Wonder if there's something that would complete the process? It's still a little noisier than the less-used right click.
por
Thank You So Much
por
Pergunta mais útil
I just had the same thing happened and I held down the button and blew really hard into the area. Good as new! A trusty old Nintendo trick! :)
Pontuação 10
5 comentários:
this is amazing!!!!!!!!
por
Worked right away!
por
omg this worked!!!!!!!
por
this actually worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
por
wtffffff, just workeddddd!!!!!
por
Try tilting the Book and see if you can get the obstacle into a corner, tapping the button lightly. Then use a business card to push it out.
Pontuação 2
it just worked for my dell, the problem is little particle of dirt or food , stick a small piece of paper in the edge around the touchpad thing and go all the way around then blow all the way around really hard and it should fix it. i promise, may not seem as if thats the problem but it is. it did fix mine.
Pontuação 0
Adicionar a sua resposta
10858083 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 51
Ao todo: 24,303
