Ir para o conteúdo principal
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
Why Do I have to put preasure on the screen?
I have to put pressure on the screen for the pixels not to be super dim to the point of barely being seen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
iFixit does have a guide to reflowing the solder on the ribbon cable that's probably no longer making good contact. It appears to require a heat gun for the top cable, but the bottom one can be done with a soldering iron.
How to Repair a Glitchy TI-83 Plus Screen - iFixit Repair Guide
Esta resposta foi útil?
Pontuação 1
Which part of the screen are you putting pressure on?
Most of the time screen issues are due to the ribbon cable degrading. It will likely only get worse with time and there's no permanent fix.
Pontuação 0
Adicionar a sua resposta
John Cole será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 54
