Introdução
If your screen is missing lines or is glitchy this guide is for you. The screen is attached via ribbon cables that are made of conductive glue and plastic. Applying heat and pressure to these cables might just be the solution for you.
O que você precisa
Remove the battery cover and the batteries that come with it.
Set your heat gun to the lowest setting(around 150 degrees)
If you are missing lines on the screen, aim at the top ribbon cables and heat the cable evenly for about 5 seconds.
Then heat and apply pressure using the plastic opening tool for about 5-10 seconds, applying pressure to different sections of the ribbon cable within that timeframe.
Continue to apply pressure throughout the ribbons.
If the screen is Glitchy, do the same for the bottom ribbon cable.
Uma outra pessoa concluiu este guia.
