Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a 7ª geração do Apple iPad com Wi-Fi, disponível com 32 ou 128 GB de armazenamento. Lançado em setembro de 2019. Identificado pelo número de modelo A2197.
TG0B Kernel Panic
Got the same issue
I replaced the battery but still getting the TG0B error. The battery level is fluctuating as well. I checked the capacitor C8923 and I got diode resistanc f .883 not sure if this is too high. FL8900 is good as well. What Iam not sure is the Q8900 which for BATT_SWI_FL.
The C8922 which is for BATT_NTC is ok as well it go straight to PMU chip. I tried to jump a wire from the battery terminal directly to batt_ntc n C8922 in case the connection going to the battery is loose but still getting TG0B ... This issue is a pain.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Adicionar um comentário
1 resposta
Did you screw in the battery all the way? I had this error as well on my iPad 7 after a logic board swap. It kept having a kernel panic and reboot every 1-3 minutes or so, and the battery wouldn't charge anywhere past 19%. Turns out I forgot to screw in the battery which was causing the connection between the logic board and the battery to be weak. Try screwing the battery if you need to, if not, then not all pins might be making a connection which would require some soldering.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jerson Macapanas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 232
