Ir para o conteúdo principal
Ceiling fan running slow
My Casablanca ceiling fan runs quite slow even when on high. I looked up online to see how to fix a slow running fan and most solutions seem to be to replace an old capacitor. I opened the hood of my ceiling fan to take a look at the capacitor but unfortunately I don't see one that is easily detachable. I'm looking for some help on how to fix this particular model
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Are there speed controls on the fan (Like a pull chain) as well as a wall control unit? Was anything recently changed with it? If there is a pull chain on the fan, with the wall switch on high, click through the pull chain speed control until it's at the fastest by watching the fan.
Esta resposta foi útil?
Pontuação 0
2 comentários:
There is a pull chain on the fan. Pulling on the chain changes the fan speed. The fan runs slow when both the pull chain and the wall control are set to high.
por
@vittalprem29151 You might try bypassing the wall control and see if the built in pull chain will let you get to full speed. This could help troubleshoot a faulty wall unit.
por
How to change the cell
Pontuação 0
How to change cell
Pontuação 0
Adicionar a sua resposta
Vittal Premachandran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 741
