Ir para o conteúdo principal
Anunciado em 13 de outubro de 2020, o iPhone 12 mini é uma versão menor do iPhone 12 da Apple. Ele possui uma tela OLED de 5,4 polegadas, um processador A14 Bionic e câmeras traseiras duplas.
Sim tray inserted wrong way
I have inserted my a sim tray from different iphone and inserted it in this one, that too the opposite way/the other way around. Now the tray is half way stuck and it’s not coming out.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
If it's jammed, then pulling it out will either break the tray, leaving half still stuck inside, or damage the sim, or warp the sim reader
Solution: get a spare sim reader part, and then pull out the old one, with pliers if you need to. If it breaks or scratches, you get the spare reader
Esta resposta foi útil?
Pontuação 0
Sounds like you have damaged the sim reader by trying to pull it out. The tray has probably caught up in the sim contacts inside the reader effectively trapping it. Try this.
Cut a fine piece of plastic just slightly narrower than the sim card. Slide it gently into the sim slot above the tray that is stuck inside. If the plastic jams you may have to push the tray slightly so it moves away from the contacts. If the plastic goes all the way in try pulling out the tray.
Pontuação 0
Adicionar a sua resposta
Awez Ali será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 394
