Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
iPhone 8 not recognizing Charge. Suggestions?
Hi I am hoping this gets some attention before I send my phone away, im pretty sure i know whats broken but just want to check to see if there's anything else I could check first.
I was working on my iPhone 8 as it needed a new Battery as I was working on it I accidently broke the ribbon connector for the Taptic Engine, I finished installing the battery while i waited for a replacement engine and the phone worked fine. However While i was Taking it apart to replace the Taptic i forget to disconnect the battery in my haste and now the phone will not show battery Percentage or seemingly charge, it will eventually show a percentage after sitting on a wireless charger for a while but in that time it randomly turns on and off. all i have found googling is that I must have damaged the MOSFET's, they dont look damaged but they could be.
Sorry for the long Question hopefully it makes sense.
Does anyone else have suggestions on what else it could be before i send it away?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Adicionar um comentário
1 resposta
I'd recommend changing out the entire charging port flex cable.
You can find the part with or without the exact toolkit you need
HERE
Substituição do cabo flex da porta de carregamento do iPhone 8
Imagem de Replace a lightning connector assembly compatible with the iPhone 8. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-01163.
Produto
iPhone 8 Lightning Connector Assembly
$49.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
que que será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 168
