Ir para o conteúdo principal
O Bose QuietComfort 35 II (número do modelo: 789564-0020) é um fone de ouvido Bluetooth com cancelamento de ruído projetado pela Bose. O dispositivo vem com um carregador USB e um cabo com entrada para fone de ouvido, sendo compatível com dispositivos Bluetooth iOS e Android.
Is it possible to replace the volume controls?
The reduce volume button has broken off of my headphones and the increase volume button is also in danger of breaking off. While there is still a smaller button I can press inside what remains of the original button, it would be nice to not have the headphones be obviously broken.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@hectorgrey post a picture of what this all looks like so we can see what you see. They are most likely soldered to the circuit board so we would need to try to find replacements. Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
Volume buttons on headphones may be just carbon contacts or actual switches, but they are tiny. Getting to them without damaging a plastic part is also tricky. If switches, they can be replaced if you can find the part. If it is just the button itself that pushes on the switch, it would only be available from Bose IF they even sell it. Unfortunately, I have no experience with Bose.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
hectorgrey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 28
Ao todo: 319
