Ir para o conteúdo principal
Repair and disassembly information and guides for Nespresso coffee makers and accessories.
EN750MB Brewing Unit - How to replace
Hi,
What is the procedure to replace the browning unit?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The procedure to open the machine in order to get to the brewing unit is quite similar to the Lattissima Plus and the Lattissima Touch.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Is there a specific tool to push back the tube to the brewing unit nozzle before adding the clip?
por
Normally you just insert the tube into the back of the brewing unit. Maybe wiggle a bit to get it in all the way.
If it resists to go in enough to add the clip, you could try to lubricate the outside of the tube that goes in there
por
Adicionar a sua resposta
Zohar Fuchs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 206
