Ir para o conteúdo principal
Lançada no Japão a 12 de Dezembro, 2004, na América do Norte a 24 de Março, 2005, e na Europa a 1 de Setembro, 2005.
Non-functioning wi-fi switch on PSP1000
Hello,
I think the switch broke around 15 years ago, but there's no pressure on the physical switch on the left side of the console. Looking for advise or if there is even parts that are available before I start unscrewing anything
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi MattR!
This one is soldered on the motherboard unfortunately.
If you have soldering experience, you can replace it!
The part can be found here: https://store.richspsxparts.com/newinwls...
If you don’t know how to solder, it’s recommend to learn this first.
You can replace the motherboard, but this will be more expensive!
Please let me know if you need any guide!
Esta resposta foi útil?
Pontuação 2
2 comentários:
I have some soldering experience but mostly just some light plumbing and breadboarding in high school 10+ years ago. I think I’m up for the challenge though! A guide would absolutely be appreciated too!
por
Ah, then it will be a challenge, but it's fun to do!!
Guide: Substituição da placa-mãe do PSP 1000
This guide is meant for taking the motherboard out. The part you need to replace, can be seen in the link where you can buy the part! If you need something more detailed, let me know! Good luck with the repair!!
por
Adicionar a sua resposta
MattR será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 63
Ao todo: 680
