Ir para o conteúdo principal
Reparo e suporte para os controles que acompanhavam o PS3. Lançado em novembro de 2007 (apenas no Japão) e em 2008 (outros países), o controle com bateria de lítio e seis eixos (CECHZC2) é simples de consertar.
Why are the R1 and R2 buttons not responding?
I bought a few brand new PS3 controllers from Amazon. Two came in a pack and one works fine. The other one works fine except for the R1 and R2 buttons. The buttons aren't broken, and when I took it apart, I tried using the sensors to push the buttons and it didn't work. I did the same for the L triggers and it did work, so I know it's supposed to work. All the connections and ribbons look fine, and it's brand new, so it's clean inside. The sensor pads and everything look fine, too. I don't know what else to do. Any advice?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
I would return it for warranty and get yourself a new one. If they are brand new, they should replace the controller!
Most likely caused by the circuit button membrane. Replacing this could solve it! But again, just get yourself a new one with warranty!
Esta resposta foi útil?
Pontuação 2
2 comentários:
That's what I was planning to do if I couldn't fix it myself. If it requires replacing something then I'm just going to try to return it. Thanks!
por Compartilhar
My pleasure! Yes, the button membrane circuit need to be replaced to get it working. Have a nice day!!
por Compartilhar
Adicionar a sua resposta
Charity Senger será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 48
Ao todo: 665
