Ir para o conteúdo principal
Repair guides and support for medical walkers. A walker or walking frame is a mobility tool used for disabled people who need additional support to maintain their balance or stability while walking.
Drive Nitro Rollator won’t steer
We have a Drive Nitro Sprint Rollator but the front wheels do not to turn right and left making steering virtually impossible. It’s like they are sticking. Is there a way to correct this?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@sharon75911 did the wheels work for you before? Anything happened to the walker? Both wheels are independent from each other so for both to be stuck, something is definitely off. I would suggest you post some pictures of the Nitro so we can see the front wheels etc. Adicionar imagens a uma pergunta já existente
por
They worked when I bought it new in October 24. First the right stopped turning. I tried to add spray lithium grease but it won’t go down into the casing. Now the left one doesn’t want to steer. No damage has occurred to the Rollator.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @sharon75911
Here's an article that may help.
There's a 2 year warranty on the walker (see p.8 in the manual), but it seems that castors aren't included if they go faulty, but I may be wrong.
Here are the parts lists for the 3 variants of your model walker, if you decide to replace the castors, although for the castor components they're all use the same parts.
Standard, Hemi & Tall
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sharon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Ao todo: 125
