Ir para o conteúdo principal
A Ridgid R45101 é uma serra de mesa de obra de 10 polegadas lançada em 2012.
On off switch smokes
Hasn’t been used for a while is plugged into 20amp plug with 12 gauge extension cord. Motor started as usual and stepped up to full rpm. Made 1 cut ok. Switched off next cut turned on stepped up then quit. Went to flip switch off and wispy smoke was coming out of switch. Unplugged and here I am
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Bod,
usually the switches can handle much more current than the nominal current of the device. Please check if there is dust and moisture concentration on-in the switch. Otherwise I would recommend to find a replacement part. If you reach the switch you can also check if there are any cables almost detached from the switch itself.
good luck
Esta resposta foi útil?
Pontuação 1
1 comentário:
Agreed. Switch or attached wiring looks suspect. Smoke comes from severely overheated cable insulation when the conductor is carrying too high a current. If the db board switch didn't trip, it indicates a dead short is not likely. Another cause should be looked for as suggested by Gavriil. If you can measure the current it may tell you something for example a field or armature winding problem. If the very thin insulation coating of these windings overheat they may cause a local inter coil short, increasing the current and thus the heat generated. These motors are usually protected by a thermal cutout fuse to prevent motor damage. They usually fail permanently but can be replaced (if you can locate it). However the cause must be established.
por Compartilhar
Adicionar a sua resposta
Bob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 249
