Ir para o conteúdo principal
My pro controller doesn’t charge
I just replaced the battery in my pro controller thinking that it was a bad battery, it lasted for a while but when I went to change the controller it wouldn’t charge and now it only works when plugged in, what could be wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Caleb!
Okay, so when you keep it plugged in, it works all fine?
It does sound like a broken battery.. Maybe the replacement part is faulty too. I would return the battery and get yourself a new one again and see how that goes.
If the exact same issue is happening again, then you might want to check the motherboard as well.
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 2
6 comentários:
Thank you, I will let know
por
Thanks Caleb!
por
Update on my pro controller just randomly when I was using it while plugged in I noticed that it showed the battery was fully charged so I unplugged it and it worked just fine. Weird hun?
por
So now it is working fine?? Then it is most likely related to the battery. You can just try and use it as it is now, or replace it and see how that goes!
por
Yep it’s working fine now the only other problem is the left sticks pad has snapped off and the mechanism itself sticks in some positions but besides that it’s in great condition
por
Exibir mais 1 comentário
Adicionar a sua resposta
Caleb Skatvold será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 40
Ao todo: 245
