Damaged speaker driver and replacement
Hi, the left speaker on this wireless headphone stopped working a while ago and I decided to take a look at it now. Opened it up and there was no broken wires or anything. Tested the continuity and it was fine.
Then I checked the resistance and one of them showed around 22 ohms while the dead one was at 1000+ ohms. Which makes me believe the speaker itself is the issue. Note: I didn't disconnect the wires from the speakers when testing.
Is it possible to fix it? Can I replace it with speakers from an old headphone? Would I have to replace both? If I decide to buy a replacement, would it have to be the same impedance?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Sony CH520 RHS driver is broken...
por Compartilhar
@mahendrakhorate how do you know? what did you check? What have you tried?
por Compartilhar
Adicionar um comentário
