Ir para o conteúdo principal
Laptop da Lenovo lançado em 2019, número do modelo 81LW000QSB.
Does it support eGPU?
So i know that the Lenovo L340-15API 81W has an M.2 ssd slot that supports NVMe. but if i connect a real GPU with an adapter to the M.2 slot can i actually use it with a monitor? If someone actually tried this for some reason pls give an answer(i dont wanna waste money)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If it has an M.2 slot, and you have an adapter, you can indeed plug in an eGPU
But, there are some downsides
1 - The laptop likely won't be possible to close back up again
2 - You will likely need to reinstall windows afterwards
3 - It's very costly
If it was a desktop, I would go for it, but this is a laptop so I'd rather not sacrifice it's... laptop-ness
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ferenc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 206
