Ir para o conteúdo principal
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
My iPod Shows No Signs Of Life. ):
in 2020 I lost this iPod And It was working at the time when I eventually found the iPod again a couple months later I tried to plug it in nothing happened I left it plugged in for a few hours there was still nothing happening so I gave up until now when I opened it and removed the battery to see if that was the issue but there is still nothing happening. ):
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Did you fit a new battery? Did you check the battery voltage with a multimeter? If batteries drop below a certain voltage they won't charge. That or the power ic.
Esta resposta foi útil?
Pontuação 0
Hey there. I am currently taking Apple's IT courses for device support, and I would be happy to help you out!
Your battery is most likely the issue, these devices will show no signs of life without a battery. Since you mentioned the iPod had been unused for long periods of time, this is very probable.
However, there are some things you can try before you open up the device and attempt to replace the battery:
  1. Use a different charger
    1. There is a chance that the cable you are using is damaged
  2. Clean out the port
    1. Using a toothpick, clean out any dryer lint or dust that has built up in the charger port, both lint and dust can cause faulty connections
  3. Connect the iPod to a Mac or PC
    1. Does the device show up in the Finder or iTunes? If so, let me know, and we'll go from there.
In conclusion, your device may not be completely dead. Try these suggestions and let me know what you discover!
Pontuação 0
Adicionar a sua resposta
Caleb Churchill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 58
