Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
Battery Indicator Board missing
I've been working on a 13" mid-2010 MacBook Pro. I've assembled it, short of installing the hard drive. But when I connect it to MagSafe, the LED on the charger doesn't turn on. It did once or twice, but only for like ~15 seconds, then turned off. I checked the connection on the DC-in board, and it's fine (I just got a new one).
Then I was looking at an iFxit guide and saw that it included a cable that connects to the motherboard for the battery indicator light. In mine, there wasn't one attached. Looking further, the cable had been cut. I will need to get a new one nonetheless, but I'm wondering if this would cause the Mac to not charge and leave the MagSafe cable LED blank.
Thank you in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The LED indicator on the side will not affect charging or anything if it is not connected, it is just an indicator light. I have seen many of these broken in the past, they are really fragile and break to easily.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
S.I. Dalton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 154
