Ir para o conteúdo principal
Um controle de videogame sem fio, mais tradicional, produzido pela Nintendo para o console Switch. Número do modelo: HAC-013.
Why does my pro controller not charge?
So, a while ago, my pro controller's R button cap snapped in two. I took the remaining part of it off, but now the controller is refusing to charge and doesn't look like it's even detecting the battery at all. What do I do? I opened it up and the power daughterboard and the pins look alright, is there something I'm missing?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Did you tried to replace the battery for a new one and see if that worked?
por Compartilhar
Adicionar um comentário
1 resposta
Hi, Well I might sound bit rude but I will suggest you to buy a new controller this the best solution because as a gamer i also face this kind of issue and after doing research and speed hours searching online on the internet I did't find a proper solution so after doing all of this I have deiced to buy a new one and it work fine now.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
MrMoldey27 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 304
