Ir para o conteúdo principal
Informações de reparo e guias para o iPhone 8, lançado em 22 de setembro de 2017. Modelos: A1863, A1905
voice memos not record
when I want to record music my voice memos do not work or record my phone is iphone 8
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Do you have this problem just in voice memo?
There are 3 microphones in the iPhone.
  • The bottom microphones is for Voice Memo and phone calls. (so is possible to be the lightning connector assembly - iPhone 8 Lightning Connector Assembly)
  • The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera.
  • The (top) back microphone is used for videos with the rear camera .
  •  If the issue affects more than one microphone, then it could be the Audio Codec IC on the logic board. Anything at the logic board level will require micro-soldering so you would need to find a repair shop that offers those services.
Imagem de Replace a lightning connector assembly compatible with the iPhone 8. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-01163.
Produto
$49.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Singtan Sing like será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 135
