Ir para o conteúdo principal
Repair guides and support for the autonomous Roomba vacuum cleaning robots by iRobot.
Not holding a charge
My iRobot 17070 will not hold a charge
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Nelda,
It appears that model number 17070 is the charging base itself that fits several different models of Roombas rather than being the model of the vacuum itself.
I'm assuming you mean the robot won't hold a charge rather than saying that the charging base won't hold a charge, so we would need to know the model number of your vacuum itself in order to give you any more help.
At this point it sounds like you are probably in the market for a replacement battery and once we have the model number we should be able to tell you how to replace it.
In the meantime, you might check out the troubleshooting guide for Roomba vacuums that won't charge.
Roomba Won't Charge - iFixit Troubleshooting
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nelda Kubicek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 70
