Why is my PC charging but not powering on
Esta é uma boa pergunta?
Probably a Problem with the Motherboard. If you hear a Fan Spin, its probably the Screen.
Esta resposta foi útil?
If your laptop shows charging but won’t power on, try these quick checks:
We see this often with EliteBooks, and many times it’s a simple power reset or RAM reseat. If not, it usually points to a board-level issue.
@abdullahideeq @kevin11129 you have not told us how old your battery is. Your PC may say it is charging but a dead battery will not hold a charge. I'd start with a new battery and go from there. If nothing else, it will provide you with a known-well starting point for any further troubleshooting, if necessary. Use the HP EliteBook 645 G10 Maintenance And Service Guide to work on it.
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 305
1 comentário
My laptop charging but don't working when unplug the charger it is of
por Abdullahi Deeq
