Ir para o conteúdo principal
Cortador de grama a gasolina Murray® de 22 polegadas 2 em 1 com tração própria e motor Briggs & Stratton® de 140 cc
No drive to wheels
Change the drive belt
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
The front wheel drive stopped working on my Murray 22 inch front drive mower. I couldn't get the cover off the wheel drive. I took off two big and two small screws underneath but the cover would not come off so I took off the blade, removed the 3 nuts on the engine pulley cover, found the belt slipped off the engine pulley. I took off the pulley, watch for the Woodruff key, kind of a trick to get it back into the engine pulley. The belt looked okay. The side of the plastic engine pulley may have to be replaced but I put the belt back on. Reassembled and it worked okay but I will eventually have to get the drive cover off and replace the belt. Any help here?
Jerry in Kentucky.
por
Adicionar um comentário
1 resposta
Here's a page from the manual that might help. Good luck.
En 2a8a513128c1d33166c65ab81a984af2
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dennis schweitzer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 74
Ao todo: 567
