Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
Could someone make a microphone replacement guide?
Hello world,
I'd like to someone make a microphone replacement guide because my iPhone 8 fell (a long ago) and down right corner broke, so the microphone died. None can hear me on calls, audios etc. I hate that when someone calls me, i have to run to take and plug the earphones, so could someone make it?
Or tell me if the micriphone is included on the speaker replacement so i change it (it also started to fail)
Thank you.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
P.S:
I didn't tell you, but it fell two or three more times and in one of them I remember that something really tiny went off (because the screen broke and it had a hole). I alredy changed the screen.
por
Adicionar um comentário
2 respostas
Solução escolhida
The microphone is part of the charging port flex so you’ll need to fit a new port.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Oof, it will be hard, but thanks :D
por
Hey kinda unreleated comment but I'm dealing with a similar issue to this but it has to do with the screen of the iPhone
por
Take out the chargeing port than take out the mic I think
Pontuação 0
Adicionar a sua resposta
Invisible_guy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 196
