Ir para o conteúdo principal
Laptop da linha Republic of Gamers lançado em 2015. O GL551J possui uma placa de vídeo GeForce GTX 860M e uma tela Full HD de 15,6 polegadas com resolução de 1080p.
tab key is not working
keyboard tab key is not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Well you try the different keyboard and check if the tab key is work or not of that keyboard as well and also check for the outdated keyboard driver as well some time an outdated driver can be the reason of this kind of issue as well you can check the driver manually or you can check the outdated driver with a good tool which can help you in update the driver as well like Advanced Driver Update or any other good driver updater tool.
Esta resposta foi útil?
Pontuação 0
Well you try the different keyboard and check if the tab key is work or not of that keyboard as well and also check for the outdated keyboard driver as well some time an outdated driver can be the reason of this kind of issue as well you can check the driver manually or you can check the outdated driver with a good tool which can help you in update the driver as well like Advanced Driver update or any other good driver updater tool.
Pontuação 0
Adicionar a sua resposta
German T será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 194
