Ir para o conteúdo principal
Lançado em julho de 2018, o MacBook Pro de 15", modelo A1990, possui uma tela de 15,4 polegadas com retroiluminação LED e tecnologia True Tone, TouchID e processador Core i9 de até 6 núcleos.
Battery changed - still shows Service Recommended
I changed the battery and got the computer all put back together. It charges and seems to hold a charge longer . When I first powered on the Mac Pro - for a short time the Service recommended notice went away but is now back. I tried resetting the SMC but does not seem to have changed anything. I loaded Coconut battery and still shows the original battery information.
Imagem
Could there be an issue with the Battery Board Data Cable if it isn't seated properly ? Wanted to ask for some advice before taking the computer apart again
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Did you install a new battery or an already used one?
por
A new battery from iFixit.
por
@livfe that was my doing since it worked for the OP, it is a great answer that will potentially help many others. I did change it back
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Let's see if a hard SMC reset fixes this. Carefully disconnect the batteries connection, leave the Battery data cable connected. Now press the power button and hold it for a good 15 sec's this drains the charge within the logic board. Now plug in the MagSafe to power the system I haven't tried this yet on a M Series system so I'm sure what will be the reaction. Intel system tend to spontaneously restart. Give it a chance, then disconnect the MagSafe charger and reconnect the battery and restart the system did that alter CoconutBattery give it a good minute to recache the values.
Esta resposta foi útil?
Pontuação 1
12 comentários:
Thanks! I'll give it a shot and report back
por
Open finder, preferences, select to show your macbook (Under iCloud), user name / library / com.apple.power (3 files) - delete them, empty trash, restart.....
por
I disconnected the battery and pressed the power button for quite a while (more than 30 seconds). When I plugged the charger in - it stayed dead. No sign of life after waiting a bit. I disconnected the charger, connected the battery and had some trouble getting it to turn on. I needed to plug the charger back in and then it restarted. Unfortunately CoconutBattery still thinks it is the old battery and still recommends service for the battery.
por
@laurenf48722 Did you try this? Open finder, finder preferences, select to show your macbook (Under iCloud), user name / library / com.apple.power.plist (3 files) - delete them, empty trash, restart..... (com.apple.powerlogd / com.apple.PowerManagement / com.apple.PowerManagement*)
por
@laurenf48722 - See if deleting the files Livfe pointed to fixes things.
por
Exibir mais 7 comentários
I'm in this position now, replacement went great, but it's still showing as "service recommended". I've deleted the power profiles in /Library/Preferences and after a reboot it's still showing the same message. I'm on a Macbook Pro A2338 M2, running Tahoe.
Pontuação 0
Adicionar a sua resposta
Lauren F será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 123
Ao todo: 1,713
