Ir para o conteúdo principal
O Kobo Mini é um pequeno e-reader (leitor digital) com tela tátil, produzido pela Rakuten Kobo Inc., ou Kobo, uma empresa canadense que vende e-books, audiobooks, e-readers e tablets. O Kobo Mini foi lançado em setembro de 2012 e comercializado para pessoas que desejavam um e-reader de bolso.
Doesn't work unless plugged in.
Think it just needs a battery replacement. How much does that cost?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @monkeyman18935
Battery replacement will only be the cost of the battery ( + shipping) if you do it yourself.
Here's the ifixit Desmontagem do Kobo Mini guide.
The battery can be seen in the image in Step.3.
Not sure if it is glued down or not (most probably is) so be careful if you have to prise it out, that you don't puncture it. Use a syringe and run a line of Isopropyl Alcohol 99%+ (available from electronic parts stores) down the edge of the battery to loosen the adhesive underneath it. Then prise it up a bit at a time applying more alcohol each time. Do not use liberally as you don't want to make things too wet.
Remember to disconnect the battery as soon as you can access it so as to avoid the possibility of any electrical problems from occurring whilst doing the replacement.
Search online for GN344658 3.7V LiPo battery to find suppliers that suit you best. Here's just one example to give you an idea of the cost of the battery (+ shipping).
If you do decide to do it yourself, please dispose of the original battery responsibly. The environment will thank you for doing this.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Monkeyman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 289
