Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Left Speaker Replacement Does Not Work
Replacement speaker has very low volume and the sound is tinny. Is this the part or something I have done?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@gilipatric84137 quick Question. why did you replace the speakers? What was wrong with them in the first place?
por
Adicionar um comentário
2 respostas
That sounds like a bad speaker. Where did you get the part? See if they will send you a replacement.
Esta resposta foi útil?
Pontuação 0
The original & OEM speakers for these 13" & 15" Retina models are 'not exactly of the best quality" and are notorious for failing easily, depending on your location give The BookYard a shout to see if they have an original set in stock as they do ship orders out worldwide.
Pontuação 0
Adicionar a sua resposta
gilipatrickr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 106
